Also ich habe nach fast 7000 auslösungen keinen FF bemerkt. Die Schärfe sitzt da wo sie soll. Egal ob Kunstlicht oder Tageslicht!
Das beruhigt - werde mal probieren, wenn sie da ist!
In eigener Sache!
Wenn das so extrem ist, dann ist das nicht normal. Ich denke, an deiner K-5 stimmt irgendetwas nicht. Ich würde also Umtausch/Service in Betracht ziehen.eigendlich bekomme ich kein Bild scharf, der fFokus liegt immer einen halben Meter vorneweg.
Wie gesagt, nur bei Kunstlicht oder/und mit Blitz.
Bei Tageslicht ist alles io.
Ich glaube deshalb das der Rot-anteil des Kunstlicht das Problem ist.
Hi, I'm an admin for Pentaxeros.com, Pentax forum in Spanish, and a photography shop specializing in Pentax.
Long ago, a study that reports to Pentax focus on the problems under tungsten light.
Explore more than 25 units of K-5, and all respond the same way.
The conditions are as follows, and the Front Focus is produced is always the same under these conditions.
Lighting conditions are:
1 / 10 ISO 3200 f: 2.8 and light Tunsgeno
Under similar exposure parameters, tungsten light, there is a front focus that can be corrected at the option of micro adjustment with an adjustment of -10
However, under the same light intensity, but with natural light, the focus is perfect.
The problem is further accentuated with screw-focused lenses. SDM lenses I have not detected.
The study was carried out under controlled conditions tested, the K-7, K-5 and Kr
The K-7 always well focused, the approach was slow, but accurate.
The K-5 and Kr under tungsten light always had a focus of -10 Front
The error report it to Pentax, together with all the serial numbers analyzed, and RAW Pentax shots taken and I have been informed that work to fix it through firmware.
I hope I have shed light on the subject, plus I also know that will be solved soon.
Best Regards ...
Read more at: http://www.pentaxforums.com/forums/...cus-under-tungsten-light-2.html#ixzz18aJMnQQe
oder nimm LV.
