---- ExifTool ----
ExifTool Version Number : 9.46
---- File ----
File Name : ex-pic01.jpg
Directory : xxxxxxxxxx
File Size : 9.3 MB
File Modification Date/Time : 2015:02:15 14:14:50+01:00
File Access Date/Time : 2015:02:15 14:14:51+01:00
File Inode Change Date/Time : 2015:02:15 14:14:50+01:00
File Permissions : rw-rw-r--
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Image Width : 6016
Image Height : 4000
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
---- EXIF ----
Make : RICOH IMAGING COMPANY, LTD.
Camera Model Name : PENTAX K-3
Orientation : Horizontal (normal)
X Resolution : 300
Y Resolution : 300
Resolution Unit : inches
Software : PENTAX K-3 Ver. 1.11
Modify Date : 2015:02:05 21:13:57
Artist :
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/1000
F Number : 2.8
Exposure Program : Manual
Sensitivity Type : Standard Output Sensitivity
Standard Output Sensitivity : 200
Exif Version : 0230
Date/Time Original : 2015:01:05 16:03:32
Create Date : 2015:01:05 16:03:32
Components Configuration : Y, Cb, Cr, -
Flash : Off, Did not fire
Focal Length : 200.0 mm
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 6016
Exif Image Height : 4000
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Manual
Focal Length In 35mm Format : 300 mm
Scene Capture Type : Standard
Contrast : High
Saturation : High
Sharpness : Hard
Subject Distance Range : Distant
GPS Version ID : 2.3.0.0
Compression : JPEG (old-style)
Thumbnail Offset : 32130
Thumbnail Length : 6826
---- MakerNotes ----
Pentax Version : 11.0.0.0
Pentax Model Type : 0
Pentax Model ID : K-3
Date : 2015:01:05
Time : 16:03:32
Quality : Best
Flash Mode : Off, Did not fire; Internal
Focus Mode : AF-C (Release-priority)
AF Point Selected : Lower-right; 0
AF Points In Focus : Lower-right
ISO : 200
Exposure Compensation : +1.3
Metering Mode : Multi-segment
Auto Bracketing : 0 EV, No Extended Bracket
White Balance : Daylight
DSP Firmware Version : 1.11.28.18
Effective LV : 13.4
Image Editing : None
Picture Mode : Manual; 1/3 EV steps
Drive Mode : Continuous; No Timer; Shutter Button; Single Exposure
Lens Type : Unknown (8 60)
Sensitivity Adjust : 0
Image Edit Count : 0
Camera Temperature : 10 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0; 0
Image Tone : Bright
Shake Reduction : Off (AA simulation off)
Shutter Count : 2097
Faces Detected : 0
Face Position : 0 0
Raw Development Process : 13 (K-3)
Hue : Normal
White Balance Auto Adjustment : Off
Tungsten AWB : Subtle Correction
Dynamic Range Expansion : Off (auto)
World Time Location : Hometown
Hometown DST : No
Destination DST : No
Hometown City : Tokyo
Destination City : Tokyo
High/Low Key Adj : 0
Contrast Highlight : 0
Contrast Shadow : 0
Contrast Highlight/Shadow Adj : Off
Fine Sharpness : Off; Normal
High ISO Noise Reduction : Weak; Active (Weak)
AF Adjustment : 0
Monochrome Filter Effect : None
Monochrome Toning : None
Face Detect : On (5 faces max); 0 faces detected
Face Detect Frame Size : 0 0
Shadow Correction : Auto
ISO Auto Parameters : Standard
Cross Process : Off
Distortion Correction : Off
Chromatic Aberration Correction : On
Vignetting Correction : Off
Bleach Bypass Toning : Off
Aspect Ratio : 3:2
HDR : Off; Auto-align Off; n/a; 0
Black Point : 1 1 1 1
White Point : 18400 8192 8192 12576
AE Exposure Time : 1/965
AE Aperture : 2.8
AE ISO : 200
AE Max Aperture : 2.8
AE Max Aperture 2 : 2.8
AE Min Aperture : 23
AE Min Exposure Time : 1/7723
Auto Aperture : On
Min Aperture : 22
Lens F Stops : 8.5
Nominal Max Aperture : 2.8
Nominal Min Aperture : 23
Max Aperture : 2.8
Manufacture Date : 2013:09:30
Production Code : 2.1
Internal Serial Number : 7006203
Power Source : Body Battery
Body Battery State : Full
Body Battery Voltage 1 : 6.98 V
Body Battery Voltage 2 : 6.74 V
AF Predictor : 903
AF Defocus : 2
AF Integration Time : 0 ms
Kelvin WB Daylight : 5205 0 2.2388916015625 1.393798828125
Kelvin WB 01 : 2500 0 1.21484375 2.5098876953125
Kelvin WB 02 : 2630 0 1.27734375 2.4044189453125
Kelvin WB 03 : 2780 0 1.3502197265625 2.289306640625
Kelvin WB 04 : 2940 0 1.427490234375 2.1766357421875
Kelvin WB 05 : 3130 0 1.516845703125 2.056640625
Kelvin WB 06 : 3330 0 1.607421875 1.94580078125
Kelvin WB 07 : 3570 0 1.7103271484375 1.83203125
Kelvin WB 08 : 3850 0 1.822021484375 1.7213134765625
Kelvin WB 09 : 4170 0 1.938232421875 1.617431640625
Kelvin WB 10 : 4550 0 2.061279296875 1.518798828125
Kelvin WB 11 : 5000 0 2.188232421875 1.427734375
Kelvin WB 12 : 5560 0 2.3218994140625 1.3411865234375
Kelvin WB 13 : 6250 0 2.4560546875 1.2623291015625
Kelvin WB 14 : 7140 0 2.5909423828125 1.189697265625
Kelvin WB 15 : 8330 0 2.7237548828125 1.1229248046875
Kelvin WB 16 : 10000 0 2.850341796875 1.0621337890625
WB Shift AB : 0
WB Shift GM : 0
EV Steps : 1/3 EV Steps
Sensitivity Steps : 1 EV Steps
Serial Number :
Source Directory Index : 0
Source File Index : 0
Level Orientation : Horizontal (normal)
Composition Adjust : Off
Roll Angle : 3.5
Pitch Angle : -1
Composition Adjust X : 0
Composition Adjust Y : 0
Composition Adjust Rotation : 0
Contrast Detect AF Area : 0 0 0 0
Camera Temperature 2 : 12.6 C
Camera Temperature 3 : 12.6 C
Preview Image Size : 720x480
Preview Image Length : 53235
Preview Image Start : 39044
Preview Image Borders : 0 0 0 0
---- PrintIM ----
PrintIM Version : 0300
---- Composite ----
Aperture : 2.8
Image Size : 6016x4000
Lens ID : Unknown (8 60)
Preview Image : (Binary data 53235 bytes, use -b option to extract)
Scale Factor To 35 mm Equivalent: 1.5
Shutter Speed : 1/1000
Thumbnail Image : (Binary data 6826 bytes, use -b option to extract)
Circle Of Confusion : 0.020 mm
Field Of View : 6.9 deg
Focal Length : 200.0 mm (35 mm equivalent: 300.0 mm)
Hyperfocal Distance : 713.19 m
Light Value : 11.9
