dpreview äußern sich zum AF bei der Z7:
(Zu den von ihnen festgestellten "Schwierigkeiten" und Wünschen, was sich ändern sollte)
https://www.dpreview.com/articles/2670904610/five-ways-nikon-could-improve-the-z7
Ich zitiere:
„The lack of Eye AF is increasingly egregious: Sony Eye AF is nearly infallible and even allows you target desired faces on-the-fly. Less sophisticated but capable continuous eye detection is also available on Olympus, Panasonic and Fujifilm cameras so you can maintain focus on brides walking down the aisle or running toddlers.“
Stört mich theoretisch nicht, aber warum bietet die günstigere Konkurrenz das an?
„Lack of Eye AF might be forgivable if subject tracking - the ability of the camera to maintain focus on your subject no matter where it moves in the frame - worked as well as Nikon DSLRs' industry leading '3D Tracking' mode. A D850 is capable of sticking to the eye of a subject as long as you initiated focus on it. But on the Z7 subject tracking is unreliable and imprecise, with a subject recognition area so large that quite often you can't target your specific subject precisely.“
Warum kastriert, verschlechtert Nikon die AF Eigenschaften der Z7 zu gleichpreisigen Produkt aus der Eigenen Dslr Produktschiene?
„Another issue we've encountered is how quickly the Z7's AF system begins to struggle in low light. In our shooting we've found it to be considerably lacking compared to immediate mirrorless peers. In fact from our testing, the Z7 begins hunting in light levels two to four stops brighter than comparable cameras from Sony and Canon. The 'Low Light AF' mode barely improves things. It only activates in extremely low light levels and slows down focus so much as to be impractical unless you're taking tripod-mounted shots of static subjects.“
Deutliche Worte bezüglich der Low Light AF Fähigkeit im Vergleich zu Sony und Canon (DSLM). Während eine a7riii problemlos fokussiert, kämpft der z7 Besitzer mit pumpenden AF auf dem Weihnachtsmarkt
„Better AF in backlit shots
It's not just low light situations where the Z7 AF system struggles. If you try to shoot a severely backlit portrait, particularly where your subject isn't well-lit, the Z7 often hunts and never achieves focus. This is compared to Nikon's recent DSLRs with cross-type AF points across the frame, which usually nail focus even in the most challenging conditions (as do Sony's current-generation a9 and a7-series ILCs).“
AF Gegenlicht Verhalten. Auch hier sind die günstigeren Sony Kameras besser. Und so selten kommt es nicht zu Einsatz.
„ But when it comes to continuous autofocus performance and usability, it's simply not nearly as capable as its nearest mirrorless peer the Sony a7R III, nor (in some respects) as good as Nikon's own mid-range and high-end DSLRs, including the similarly capable and priced D850.“
Damit ist eigentlich alles gesagt. Von einer Kamera für soviel Geld, erwarte ich , dass sie schnurrt und mir nicht im Weg steht. Da ist es egal, ob es die erste Generation ist. Ich hoffe dennoch, dass das System genügend Käufer findet, damit ich spätere, ausgereiftere z8 kaufen kann. Ohne die Kamera in der Hand gehabt zu haben, scheint mir das Preis/Leistung Verhältnis bei der Z7 schlecht zu sein.
