In eigener Sache!
ist ja nicht so das Sigma nichts vorgestellt hätte. Es gibt ja bereits ein sehr gutes 85/1,4. Da macht es schon Sinn zuerst andere Optiken vorzustellen.Naja wenns nach Logik ginge, müsste das Teil schon längst auf dem Markt sein.
Da sich das neue 85er so lange hinzieht... wie wahrscheinlich ist es das Sigma mit nen 1.2er daher kommt?![]()
An Nikon geht f1.2 schon aber halt nur mit nichtrunder Blende. Ab 1.3irgendwas ists dann rund.
Ich glaube aber auch nicht an f/1.2
Nikon F and Canon EF Mount Size Differences
Another key difference is the physical mount size – Nikon F mount’s “throat” diameter is 44mm, whereas the Canon EF mount is larger at 54mm. That 10mm difference might seem small, but it is actually quite important when it comes to lens design. If you have been wondering why Nikon does not release fast f/1.2 primes with autofocus, while Canon has the excellent 50mm f/1.2L and 85mm f/1.2L II lenses in its stable, the answer is primarily in the limitation of the physical diameter of the Nikon F mount. It would be very cost prohibitive for Nikon to try to design f/1.2 lenses with autofocus capabilities, because of space limitations on the rear side of lenses. Such designs would have to be limited to under 60mm focal length range and even then, the CPU contacts would probably have to be put right on the rear element. Anyone who has tried to make the classic Noct-NIKKOR 58mm f/1.2 CPU-capable knows that it requires grinding the rear element to fit the contacts – there is no other way to do it. And forget about longer focal lengths, because it would never fit. In fact, if you look at the rear of the Canon 85mm f/1.2L II, which appears significantly larger than the rear element of any Nikkor, that lens required Canon engineers to put the CPU contacts right on top of the rear glass surface. Take a look at the below image comparing the the Canon EF 85mm f/1.2L II with the Nikkor 85mm f/1.4G:
https://photographylife.com/nikon-f-vs-canon-ef
O-K.... Frage erledigt.
Zumindest eine kurze Zusammenfassung bei fremdsprachigen Artikeln gehört für mich zur Netiquette.
