In eigener Sache!
Wenn es denn ein PC wäre... ist es aber nicht.Hallo,
gibt es eine GUI für Canon Kameras, die per Firmware-Update o.ä. aufgespielt wird? Ich mag das Nikon-Menü nämlich viel lieber als das der 400D
Vielen Dank für Antworten
* RAW - CHDK can record raw files, giving you access to every bit of data the sensor saw, without compression or processing. Raw files can be manipulated on the camera, or processed on your PC. CHDK also has experimental support for the open DNG raw standard.
* Override Camera parameters - Exposures from 64s to 1/60,000s with flash sync. Full manual or priority control over exposure, aperture, ISO and focus.
* Bracketing - Bracketing is supported for exposure, aperture, ISO, and even focus.
* Video Overrides - Control the quality or bitrate of video, or change it on the fly.
* Scripting - Control CHDK and camera features using ubasic and Lua scripts. Enables time lapse, motion detection, advanced bracketing, and much more. Many user-written scripts are available on the forum and wiki.
* Motion detection - Trigger exposure in response to motion, fast enough to catch lightning.
* Edge overlay - Detect the edges in a scene, and display them later. Ideal for timelapses, stop-motion, stereography and much more.
* Live Histogram - CHDK includes a customizable, live histogram display, like those typically found on more expensive cameras.
* Zebra-Mode - Displays under and overexposure areas live on the screen.
* GRIDS - Create custom grids and display whichever one suits your shooting conditions.
* Multi-Lingual Interface - CHDK supports about 22 languages, and adding more languages is simple.
* DOF Calculator - Display detailed DOF information on the screen.
* Customizable OSD - Improved display of battery status, free space, camera parameters, and much more. Fully customizable with an on-screen editor.
* Filebrowser - Manage files without a PC.
* Textreader - Display text files on your camera.
* Games - Play Reversi, Sokoban, Mastermind or 4-in-a-Row on your camera.
* USB remote - Simple DIY remote allows you to control your camera remotely.
* Benchmark - Compare the performance of your SD cards.
* User Menu - Edit your own customizable User-Menu for fast access to often used features.
* there is even more → read the Manual & explore this wiki.
... aber das es mittlerweile Firmware Hacks gibt, mit denen man neue Funktionen in die Kamera einbauen kann, die Menüs customizen kann ...
Es ist aber ein kleiner Unterschied ob du eine GUI customizen willst oder aber eine GUI eines anderen Gerätes, ja sogar einer anderen Firma aufspielen willst.
Die Schnittstellen zwischen GUI und den anderen Klassen der Software sind ja bei der fertigen GUI gegeben und du müsstest somit die restlichen Klassen diesen anpassen.
Des stimmt wohlHat er ja mit keinem Wort verlangt... der TO is ja nich blöd wie man sieht... Er hat gefragt, ob es ne möglichkeit gibt am der Firmware was zu verändern, weil ihm das GUI (nicht die Engine dahinter!) besser gefällt!
Gibt ja auch windows User, denen OSX besser gefällt, aber die wollen nicht weg von der Dose, und wollen auch keinen halbgaren Hackintosh, also wird die GUI angepasst...
klar, Garantie ist dann futsch ...![]()
