Follow along with the video below to see how to install our site as a web app on your home screen.
Anmerkung: this_feature_currently_requires_accessing_site_using_safari
In eigener Sache!
Das sagt gar nix.
Ich habe dutzende Bilder mit dem 500/4 die richtig übel sind.
Das Objektiv wurde jetzt von LensTip getestet :
https://www.lenstip.com/index.php?test=obiektywu&test_ob=540
You should also add that its level is more or less the same as the level of the older Nikkor AF-S 300 mm f/4E PF ED VR and a bit better than the results of the Nikkor AF-S 200–500 mm f/5.6E ED VR at 500 mm.
The Nikkor AF-S 500 mm f/5.6 PF is equipped with a quiet, ultrasonic SWM motor; small wonder the autofocus work is noiseless. Still it is not fast. Running through the whole distance scale and setting the focus takes about 0.8-0.9 of a second – it is not an impressive result.
Fortunately the producer decided to add a focus limiter and it helps – after setting it on the 8 meters to infinity range the focusing time decreases to about 0.3-0.4 of a second, a very good value indeed.
Zitat von spätburgunder: Nikon AF-S 500 5,6 PF VR E
Zum Vergleich das Sigma 500/4:
Running though the whole distance scale and confirming the focus takes about 0.9-1.0 second. However, if you limit the range choosing, e.g., the 10 meters- infinity option the situation ameliorates notably – the same operation takes just 0.2-0.3 of a second.
Also ich denke damit kann man leben.
Meins ist auf dem Weg zu mir
Da bin ich auf dein Urteil gespannt
ich auch... video hatte ich schon oben drin wolfram..
