AW: Vergleich FT vs FF @ 400mmKB
Ist das so?
Ich zitiere mal DPReview
So schlecht isses also doch nicht
genau da liegt die Crux. Das E-System schwächelt derzeit an den Sensoren, und zwar mehr, als durch den Größenunterschied zum APS-C-Format erklärbar ist.
Ist das so?
Noise is slightly higher than the class average, and if you regularly shoot at anything above ISO 400 for large prints then the E-30 should probably not be your first choice; many APS-C cameras at this level do a slightly better job in the upper reaches of the ISO range. If you look closely at E-30 files you'll see noise at ISO 200 if you turn the noise filter off, or shoot raw. Until Olympus and Panasonic find a way to produce less noisy Four Thirds sensors then that will always be the compromise demanded by this format, but again the gap is narrowing and noise should no longer be a deal maker or breaker for most potential buyers.
