Für diejenigen von euch die mit der fp filmen. Hab ich folgendes erforscht.
Hi all,
I have invested much time to investigate on the monitoring and ISO behavior of the fp. Finally in combination with the Ninja V I have found a working solution for me which*gets both the monitoring picture and the metering right.
Basically after reading through your posts I understood that the fp is ISO invariant and has only two native ISO values available for metering and recording. (ISO 100 & ISO 3200) Others are digitally amplified.*
False color screen with the Ninja V is working on both of these ISO values to meter the correct exposure. However as a lot of you have mentioned the Rec709 monitor view is only showing the correct picture in ISO 100. The 3200 setting will be overexposed and useless.
After several tests I have figured out that if you set the Ninja V to PQ the ISO 3200 screen will look correct. Different story for ISO 100, but this can be tricked if you select ISO 400 in camera. Screen will look exactly the same now for both ISO values. Metering for ISO 100 is unaffected, since the false color mode is only showing the values for ISO 100.
Since the recorded ISO values of the Ninja V are pushed into Final Cut Pro X you will get an overblown picture in Rec709, BUT and this is really nice, if you select ISO 100 instead of ISO 400 and ISO 640 instead of ISO 3200 everything will look as expected. Correctly metered and captured. Remember, in the additional manual of the fp in regards to the ISO behavior, Sigma is mentioning ISO 100 and ISO 640 for photos...
If you need to work with Zebras the correct settings are for ISO 400 => 55% and for ISO 3200 => 60% if you want to avoid anything in the 100% range. You could go slightly higher as the fp has some more headroom over 100 IRE.
Quite a lot of hassle if you ask me, but once you have got used to this you will get a nice picture on both.*
Hoping this will help some of you
