Fujifilm X-T4 Praxisthread
durch das Drücken des hinteren Einstellrads kommst Du in die 100% Ansicht,
Gruß Enes
Jawoll, genau das meine ich, Vielen Dank, macht die X-T4 gleich nochmal zu ner ganz anderen Kamera. Mensch das ich da nicht selbst drauf gekommen bin.
Es gibt ein neues Firmware-Update Version 1.60
Hier der Link dazu:https://fujifilm-x.com/global/support/download/firmware/cameras/x-t4/
Revised specification from Ver.1.50 to Ver.1.60
Regarding the detail of the improvements, download the “X-T4 New Features Guide” from our website.
New Features Guide: English, Français, Deutch, Español, Italiano, Nederland, Polski, Svenska, Norsk, Dansk, Pусский, Suomi, 中文简, 中文繁體, 한국어, ภาษาไทย, Arabic
The following operational flow and functions of the zooming and focusing in the camera menu were added or changed.
・“TOUCH ZOOM” function was added in the “TOUCH SCREEN SETTING” menu, which is called through the operation flow below.
[ SETUP MENU ] ➔ [ BUTTON/DIAL SETTING ] ➔ [ TOUCH SCREEN SETTING ]
・“POWER ZOOM LENS FUNCTION(Fn) SETTING” menu to allocate the “Fn” button for the power zoom lens functions was added in “BUTTON/DIAL SETTING” menu, which is called through the operation flow below.
The functions added are “ZOOM/FOCUS CONTROL RING”, “CONSTAN SPEED ZOOM (T/W)” and “CONSTAN SPEED FOCUS (N/F)”.
・“LENS ZOOM/FOCUS SETTING” menu was added in “BUTTON/DIAL SETTING” menu, which is called through the operation flow below.
The functions added are “CONSTANT SPEED ZOOM (8 steps)”, “CONSTANT SPEED FOCUS (8 steps)”, “CONSTANT SPEED ZOOM/FOCUS (Fn) OPERATION”, “START/STOP SWITCH & ACTIVE WHILE PRESSING”, “ZOOM RING ROTATE” and “ZOOM/FOCUS CONTROL RING”.
・“FOCUS RING” and “FOCUS RING OPERATION” settings were moved to “LENS ZOOM/FOCUS SETTING” menu which is called through the operation flow below and the inscription of the “FOCUS RING” was changed to “ FOCUS RING ROTATE”.
[ SETUP MENU ] ➔ [ BUTTON/DIAL SETTING ] ➔ [ LENS ZOOM/FOCUS SETTING ]
Exposure adjustment function for the pre-view image/movie has been enhanced by optimizing the parameters for the exposure control when XF150-600mm is used.
“AF+MF” function has been available even at movie taking.
