Canon 40D angekündigt - Der Sammelthread
Status
AW: Die Daten der 40D veröffentlicht - Amazon wars diesmal
:) Hoffendlich geht meine 350 dann auch kaput, wenn ich Geld hab. Ansonsten geht der WAF gen null und ich brauche garnicht bei meiner Frau betteln:)
Ne neue Linse gibts auch:
Canon EF 14mm f2.8L II USM Lens
Designed primarily for discerning landscape and architectural photographers, the Canon EF14mm f2.8L II USM lens is ideally suited to the EOS-1Ds Mark III's full-frame capability. Measuring 3.7 inches in length and weighing in at under 23 ounces, this ultra-wide angle L-series prime lens is well corrected for rectilinear distortion, provides a 114-degree diagonal angle of view, and delivers high-speed autofocus with higher image quality overall including superior peripheral image quality, compared to its predecessor, the stalwart EF 14mm f2.8L USM lens.
While its large diameter, high-precision aspherical and UD elements, optimized lens element positioning, and flare and ghost-reducing lens coating ensure that this lens delivers the top optical performance in its professional class, Canon has added other features photographers have been asking for--improved dust and water resistance incorporated around the mount, switch panel and focusing ring, and a round aperture that creates a nice background blur and makes it easier to recognize an out-of-focus scene in less than brightly lit conditions. Furthermore, Canon has created a new lens cap specifically for the EF 14mm f2.8L II USM that is held to the lens by a stopper.
EOS-1Ds Mark III's mhhhhhhh da kommt wohl noch mehr ;)
Alle AF-Sensoren sind Kreuzsensoren, Gehäuse abgedichtet
-> zur Pentax K10D aufgeschlossen
LifeView
-> Olympus ist nicht mehr alleine
Konnte die 1D III doch auch schon.
wechselbare Mattscheiben, größerer Sucher
-> endlich zur KoMi Dynax 7D aufgeschlossen
Der Sucher meiner 30D Gehäuse taugt wirklich nicht viel, wieviel die auf 22mm verlagerte Austrittspupille und die veränderte Suchervergrößerung bringen, wird sich zeigen. Alternative Sucherscheiben gabs auch schon für die 30D, nur nicht von Canon..
Komisch, daß du die Bildqualität nicht erwähnst. Da müssen andere erstmal zur 30D aufschließen, geschweige denn zur 40D.
Grüße!
Ivh bin sehr überrascht... das ist mehr, als ich erwartet habe.
WLAN, Kreuzsensoren und einiges mehr. Die Konkurrenz darf sich warm anziehen und mein Wunsch, auf die 5D zu wechseln hat sich wohl auch erstmal erledigt...
Ich hab mir kürzlich erst die 30D gekauft, weil ich nicht auf die 40D warten wollt und dann zu 5D bzw. deren Nachfolger wechseln wollte.
Aber jetzt überleg ichs mir echt ob ich nicht doch die 40D als Zwischenlösung will :D
Kann mir mal einer erklären was so genial daran ist dass man die Mattscheibe wechseln kann?
Wow, very nice! Canon hat seine Hausaufgaben gemacht, wenn der AF gut ist und der Sucher wirklich merkbar größer, dann ist das ein Volltreffer!
Canon, you can! :rolleyes:
Das wäre doch ne würdige Ablösung für meine 350D... bleibt nur noch die Frage wo ich die Knete herbekomme... :confused:
...was ich persönlich auch sehr interessant finde ist die Custom Function "Highlight tone priority" um bei hohem Kontrastumfang mehr aus den RAWs rausholen zu können :top:
naja erstmal auf die ersten Erfahrungsberichte warten...
Die ist ja auch so schön preiswert...
Du scheinst Apfel-Birnenvergleiche zu lieben.
Du hast meinen Beitrag einfach nicht verstanden. Es geht darum, dass Canon die Probleme der 30D und das, was die Konkurrenz bisher (teilweise wesentlich) besser gemacht hat, nun auch macht bzw. verbessert. Vor allem haben sie es nach vielen Jahren endlich geschafft, dass beim Öffnen der CF-Klappe ein Warnton ertönt und nicht einfach die noch nicht geschriebenen Bilder weggeworfen werden.
Gruß, eiq
ick seh da kein 18-55 IS
Ich schon:
Amazon schrieb:
EF-S 18-55mm f3.5-5.6 IS Lens
Developed in response to consumer demand for a high-quality yet affordable optically image stabilized lens, the Canon EF-S 18-55mm f3.5-5.6 IS standard zoom lens adds a phenomenally flexible lens to the EOS 40D SLR shooter's imaging arsenal. While it features the wide-angle to mid-range zoom flexibility of its non-IS predecessor, this new EF-S 18-55mm f3.5-5.6 IS lens offers the significant advantage of a true lens-shift image stabilization system that yields up to a full four stops of image-shake correction.
The higher performance provided by Canon's lens shift IS system (compared with the in-camera sensor shift type offered in some competitive SLRs) includes the ability to optimize the lens performance for specific shooting situations such as low-light, long-zoom, or movement while shooting (or virtually any combination of the three). What's more, the shooter can see the image stabilization effect in the viewfinder. As the image already appears steady, more accurate framing and composition is possible, the AF point can be placed more precisely, and the photographer can concentrate on the optimal shot more comfortably.
Im Text ganz unten:
Nach heutigem Dollarkurs liegt das Teil deutlich unter 1000€.
Leute haut Eure 30D s raus. Wenn die 40D lieferbar ist, fällt die 30D mega ab.
dann wird morgen wohl vorbestellt :-) ich plane schon länger meine 20D nur noch als backup-lösung zu nutzen und jetzt kommt endlich adäquater ersatz auf den markt.
zum thema suchermattscheiben: ich fokussiere immer noch recht gerne manuell und vermisse einen klassischen schnittbildindikator bei meiner 20D manchmal. ich arbeite viel auf mittelformat und durch sucherlupe oder im falle des prismensuchers durch den schnittbildindikator bin ich im bereich manuelle fokussierung etwas verwöhnt ...
Klingt in Summe wirklich lecker *ggg* Jetzt mal in Ruhe die erste Lawine und den ersten Preisverfall abwarten und dann leg' ich sie mir unter den Weihnachtsbaum. :D
Ob ich jedoch so lange warten kann??? *willhabenblick*
Status
