chmee
Link zum Wiki : http://magiclantern.wikia.com/wiki/Magic_Lantern_Firmware_Wiki
Download : http://magiclantern.wikia.com/wiki/Download_firmware
Aktuelle Firmware : v0.16 - 11.08.2009
Features v0.16
Release Notes:
General
Beta Specs (Stand 06.11.09) for next Releases:
Demovideos :
http://vimeo.com/5879032
http://www.youtube.com/watch?v=8WS4VMLHV0A
Features v0.16
- Custom cropmarks bitmap file
- Live histogram while recording
- Time remaining estimate indicator
- Automated Focus pulls
- Focus stacking
- HDR exposure bracketing
- Lens data (hyperfocal distance, DOF, etc)
- Cleaner, multi-level menus that timeout automatically
- Audio monitoring can be turned off during clip review
- Internal mic can be used (must enable audio.mic-power=1 in config)
- Output audio volume control
- Configuration file can be saved to magiclantern.cfg
Release Notes:
General
- Unchipped ("Chinese") batteries still do not work
- First second of audio may be at wrong levels
- Lens info only works with modern Canon lenses
- Bracketing does not work in Manual mode. You must use either Av or Tv mode.
- Bracketing must be done in Liveview Mode (will lock up the camera, remove battery to reset)
- The camera will attempt to focus between each shot; use manual focus mode instead
- Only works in Liveview Mode
- Occasionally locks up camera (remove battery to reset)
- Zebra and cropmarks will not display correctly
- Histogram may be calculated incorrectly
- Only outputs 480p while recording (quicktime file is still 1080p)
- SMPTE Timecode
- Full HD on HDMI while Recording
- Autoboot
Demovideos :
