Follow along with the video below to see how to install our site as a web app on your home screen.
Anmerkung: this_feature_currently_requires_accessing_site_using_safari
In eigener Sache!
Hat jemad ne Idee bzw. ne Lösung zum genannten Problem?
Habe ich versucht: Geht auch nicht.
HDRI aus einer Belichtungsreihe erzeugen ....
usage: mkhdri [options] input files -? for help
invalid command line: unknown option: -logo
C:\...\picturenaut>mkhdri -?
MKHDRI - Version 1.28.0408 (2005 - 2009)
MKHDRI OPTIONS
-out:[file] output file name
-fno:[float] F-Number overwrite
-tr:[float=1.0] trim ratio to reject side areas with vignetting
-cesl:[float=0.85] curve estimation saturation level
-cenl:[float=0.02] curve estimation noise level
-ci:[file] read curve file (skips curve estimation)
-co:[file] write curve file
-a enable automatic image alignment
-eo estimate curve only
-ec disable exposure correction
-gr ghost removal
-cb enable color balancing
-ab ask for exposure bias
-wf:[d|dh1] weighting function (default is d)
-defcurve default camera curve (skips curve estimation)
-linear linear input files (skips curve estimation)
-f32 use 32-bit IEEE floating point for HDRI TIFFs
-cmdf:[file] use command file (ANSI|UTF-8|UTF-16)
-UTF8 write UTF-8 to stdout/stderr
-verbose disable verbosity
-? help
Weighting function values: d = normal
dh1 = daylight
C:\...\picturenaut-alt\bin>mkhdri -?
MKHDRI - Version 1.19.0248
MKHDRI OPTIONS
-sl:[float=1.00] saturation level
-nl:[float=0.01] noise level
-ep disable pixel based exposure correction
-? help
Verzeichnis von C:\...\picturenaut
20.10.2009 23:57 <DIR> .
20.10.2009 23:57 <DIR> ..
27.09.2009 11:33 <DIR> licenses
08.09.2009 07:52 11.362 mingwm10.dll
08.09.2009 07:52 363.008 mkhdri.exe
08.09.2009 07:52 795.648 mvs220.dll
08.09.2009 07:52 729.088 picturenaut.exe
27.09.2009 11:33 <DIR> plug-ins
08.09.2009 07:52 289.792 pncore.dll
08.09.2009 07:52 83.968 pnehfltr.dll
08.09.2009 07:52 1.132.032 pnimageio.dll
08.09.2009 07:52 127.488 pnimgbuf.dll
08.09.2009 07:52 206.848 pnres.dll
08.09.2009 07:52 263.680 tiff2jpeg.exe
11 Datei(en) 4.002.914 Bytes
Verzeichnis von C:\...\picturenaut\licenses
27.09.2009 11:33 <DIR> .
27.09.2009 11:33 <DIR> ..
08.09.2009 07:52 1.399 credits_de.txt
08.09.2009 07:52 1.166 credits_en.txt
08.09.2009 07:52 1.879 license_de.txt
08.09.2009 07:52 928 license_en.txt
4 Datei(en) 5.372 Bytes
Verzeichnis von C:\...\picturenaut\plug-ins
08.09.2009 07:52 188.416 hdrsfltr.dll
27.09.2009 11:33 <DIR> hdrshop
08.09.2009 07:52 115.712 mbilateral.dll
08.09.2009 07:52 538.112 mdcraw.dll
08.09.2009 07:52 93.184 mexptmo.dll
08.09.2009 07:52 262.656 mkhdri.dll
08.09.2009 07:52 101.888 mlogmap.dll
08.09.2009 07:52 102.912 mpptmo.dll
08.09.2009 07:52 299.520 mtonemap.dll
8 Datei(en) 1.702.400 Bytes
Verzeichnis von C:\...\picturenaut\plug-ins\hdrshop
08.09.2009 07:52 41 readme.txt
1 Datei(en) 41 Bytes
Anzahl der angezeigten Dateien:
24 Datei(en) 5.710.727 Bytes
So, habe noch einmal versucht. Der Fehler mit (logo) kam als ichvon ner älteren Version mkhdri rüber kopiert habe.
Bei der Version "\picturenaut_3_0_1526_de" bricht Picturenaut einfach ab. Erstens kommt ein Windoswfehler:
mkhdri.exe hat ein Problem festgestellt und muss beendet werden.
AppName: mkhdri.exe AppVer: 0.0.0.0 ModName: unknown
ModVer: 0.0.0.0 Offset: 7e69b1e8
Dann kommt eine meldung von Picturenaut:
MKHDRI https://bookofratricks.eu/ wurde mit Fehlern beendet.Siehe protokollausgabe -1073741819
Das Programm schließt allerdings nicht, kommt nur diese meldung.
Die Version "dist_pictn_br_2_11_dt" funktioniert"! Kopiere ich allderings von dieser die MKHDRI zu der neuen Version bekomme ich auch einen Fehler.
