; Serge Mankovski B/W Film Simulation
; Copyright Serge Mankovski (sevato@mankovski.com)
; Toronto, Ontario, 2007
; Version 1.1 March 30, 2007
; Converts selected layer into Black and White using channel mixer
; Uses channel presets found on Internet. I am not sure about the origin of these
; settings and I do not know if they really produce result resembling tonal qualities of
; the film, but it produces nice looking B/W and it is a useful way to convert to black and white
; Change Log:
; Version 1.1
; - added IR film simulation
; - added color filters applied before b/w conversion
; - added saturation option
; - Gimp 2.3.15+ support
; Version 1.1.1 Various fixes by Ari Pollak - thanks!
; This program is free software; you can redistribute it and/or modify
; it under the terms of the GNU General Public License as published by
; the Free Software Foundation; either version 2 of the License, or
; (at your option) any later version.
; This program is distributed in the hope that it will be useful,
; but WITHOUT ANY WARRANTY; without even the implied warranty of
; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
; GNU General Public License for more details.
; You should have received a copy of the GNU General Public License
; along with this program; if not, write to the Free Software
; Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
(define (create-new-layer img drawable)
(let ((layer drawable))
(set! layer (car (gimp-layer-copy drawable TRUE)))
(gimp-image-add-layer img layer -1)
layer))
(define (script-fu-bw-film img drawable film filter rename new-layer increase-local-contrast auto-levels drop-gamma saturate )
(let
((bw-layer nil)
(chan-name ""))
(gimp-image-undo-group-start img) ; Start an undo group.
(if (equal? new-layer TRUE)
(set! bw-layer (create-new-layer img drawable))
(set! bw-layer drawable)
; (if (equal? auto-levels TRUE) (gimp-levels-stretch bw-layer) ())
(if (equal? saturate TRUE)
(plug-in-colors-channel-mixer 1 img bw-layer FALSE 1.3 -0.15 -0.15 -0.15 1.3 -0.15 -0.15 -0.15 1.3)
(if (equal? drop-gamma TRUE) (gimp-levels bw-layer 0 0 255 0.9 0 255) ())
(cond
; Yellow Filter
((= filter 1)
(gimp-hue-saturation bw-layer 0 -5 0 33)
(set! chan-name (string-append chan-name " Yellow Filter")))
; Orange Filter
((= filter 2)
(gimp-hue-saturation bw-layer 0 -20 0 25)
(set! chan-name (string-append chan-name " Orange Filter")))
; Red Filter
((= filter 3)
(gimp-hue-saturation bw-layer 0 -41 0 25)
(set! chan-name (string-append chan-name " Red Filter")))
; Green Filter
((= filter 4)
(gimp-hue-saturation bw-layer 0 90 0 33)
(set! chan-name (string-append chan-name " Green Filter")))
; Blue Filter
((= filter 5)
(gimp-hue-saturation bw-layer 0 -145 0 25)
(set! chan-name (string-append chan-name " Blue Filter")))
(cond
; Agfa 200X
((= film 0)
(set! chan-name (string-append chan-name " Agfa 200X"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.18 0.41 0.41 0.18 0.41 0.41 0.18 0.41 0.41 ))
; Agfapan 25
((= film 1)
(set! chan-name (string-append chan-name " Agfapan 25"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.25 0.39 0.36 0.25 0.39 0.36 0.25 0.39 0.36 ))
; Agfapan 100
((= film 2)
(set! chan-name (string-append chan-name " Agfapan 100"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.21 0.40 0.39 0.21 0.40 0.39 0.21 0.40 0.39 ))
; Agfapan 400
((= film 3)
(set! chan-name (string-append chan-name " Agfapan 400"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.20 0.41 0.39 0.20 0.41 0.39 0.20 0.41 0.39 ))
; Ilford Delta 100
((= film 4)
(set! chan-name (string-append chan-name " Ilford Delta 100"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.21 0.42 0.37 0.21 0.42 0.37 0.21 0.42 0.37 ))
; Ilford Delta 400
((= film 5)
(set! chan-name (string-append chan-name " Ilford Delta 400"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.22 0.42 0.36 0.22 0.42 0.36 0.22 0.42 0.36 ))
; Ilford Delta 400 Pro & 3200
((= film 6)
(set! chan-name (string-append chan-name " Ilford Delta 400 Pro & 3200"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.31 0.36 0.33 0.31 0.36 0.33 0.31 0.36 0.33 ))
; Ilford FP4
((= film 7)
(set! chan-name (string-append chan-name " Ilford FP4"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.28 0.41 0.31 0.28 0.41 0.31 0.28 0.41 0.31 ))
; Ilford HP5
((= film 8)
(set! chan-name (string-append chan-name " Ilford HP5"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.23 0.37 0.40 0.23 0.37 0.40 0.23 0.37 0.40 ))
; Ilford Pan F
((= film 9)
(set! chan-name (string-append chan-name " Ilford Pan F"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.33 0.36 0.31 0.33 0.36 0.31 0.33 0.36 0.31 ))
; Ilford SFX
((= film 10)
(set! chan-name (string-append chan-name " Ilford SFX"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.36 0.31 0.33 0.36 0.31 0.33 0.36 0.31 0.33 ))
; Ilford XP2 Super
((= film 11)
(set! chan-name (string-append chan-name " Ilford XP2 Super"))
; Kodak Tmax 100
((= film 12)
(set! chan-name (string-append chan-name " Kodak Tmax 100"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.24 0.37 0.39 0.24 0.37 0.39 0.24 0.37 0.39 ))
; Kodak Tmax 400
((= film 13)
(set! chan-name (string-append chan-name " Kodak Tmax 400"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.27 0.36 0.37 0.27 0.36 0.37 0.27 0.36 0.37 ))
; Kodak Tri-X
((= film 14)
(set! chan-name (string-append chan-name " Kodak Tri-X"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.25 0.35 0.40 0.25 0.35 0.40 0.25 0.35 0.40 ))
; Kodak HIE
((= film 15)
(set! chan-name (string-append chan-name " Kodak HIE"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 1.0 1.0 -1.0 0.0 1.0 1.0 -1.0 0.0 1.0 1.0 -1.0 0.0 ))
; Normal Contrast
((= film 16)
(set! chan-name (string-append chan-name " Normal Contrast"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.43 0.33 0.30 0.43 0.33 0.30 0.43 0.33 0.30 ))
; High Contrast
((= film 17)
(set! chan-name (string-append chan-name " High Contrast"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.40 0.34 0.60 0.40 0.34 0.60 0.40 0.34 0.60 ))
; Generic BW
((= film 18)
(set! chan-name (string-append chan-name " Generic BW"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.24 0.68 0.08 0.24 0.68 0.08 0.24 0.68 0.08 ))
; 50-50
((= film 19)
(set! chan-name (string-append chan-name " 50-50"))
(plug-in-colors-channel-mixer 1 img bw-layer TRUE 0.5 0.5 0.00 0.0 0.5 0.5 0.00 0.0 0.5 0.5 0.00 0.0 ))
(if (equal? rename TRUE) (gimp-drawable-set-name bw-layer chan-name) () )
(if (equal? increase-local-contrast TRUE) (plug-in-unsharp-mask 1 img bw-layer 30.0 0.25 9) ())
; Complete the undo group
(gimp-image-undo-group-end img)
; Flush the display
(gimp-displays-flush)))
(script-fu-register
"script-fu-bw-film"
"<Image>/Colors/BW Film Simulation"
"Black and White Film Simulation"
"Serge Mankovski (sevato@mankvoski.com)"
"2007, Serge Mankovski, Toronto, ON, Canada"
"05.01.2007"
"RGB*"
SF-IMAGE "Image" 0
SF-DRAWABLE "Current Layer" 0
SF-OPTION "Film"
"Agfa 200X"
"Agfapan 25"
"Agfapan 100"
"Agfapan 400"
"Ilford Delta 100"
"Ilford Delta 400"
"Ilford Delta 400 Pro & 3200"
"Ilford FP4"
"Ilford HP5"
"Ilford Pan F"
"Ilford SFX"
"Ilford XP2 Super"
"Kodak Tmax 100"
"Kodak Tmax 400"
"Kodak Tri-X"
"Kodak HIE"
"Normal Contrast"
"High Contrast"
"Generic BW"
"50/50"
SF-OPTION "Filter"
"Select"
"Yellow"
"Orange"
"Red"
"Green"
"Blue"
SF-TOGGLE "Rename Layer?" TRUE
SF-TOGGLE "New Layer?" FALSE
SF-TOGGLE "Increase Local Contrast" FALSE
SF-TOGGLE "Auto Levels" FALSE
SF-TOGGLE "Drop Gamma 10%" FALSE
SF-TOGGLE "Saturate" FALSE
