Wieder mal das 150mm F2..
Borbarad
Ja, kommt einen doch schon bekannt vor oder?..... nach DiwaLabs & Co nun auch bei lenstip.com
Zitat:
"...What’s there to write? Looking at the graph above brings to mind one word – fabulous! This lens recorded the highest MTFs of all the tested by us... ......As we rarely see results so good, let’s enthuse about it for a longer moment. It’s worth to emphasize that such a bright lens at its maximum aperture reaches the result of almost 50 lpmm and, what’s more, it’s just under 3% worse than its maximum results. As if that weren’t enough! When we look at the edge performance we see that the lens comes off well there too. It’s proven by a small difference of MTF values between the center and the edge of the frame and also excellent behavior at maximum aperture. As regard resolution, then, Olympus ZD 2/150 has absolutely no weak points. ...."
http://www.lenstip.com/188.1-Lens_review-Olympus_Zuiko_Digital_150_mm_f_2_Introduction.html
:top:
B
