Danke für die Infos.
Exakt so sieht es aus bei mir:
"To summarize: the processing is correct - ie 5.3.2 does use the correct colour space when generating the JPEG or the Tiff from RAW.
But the X3F review window does not honour the Win / XP machine's monitor colour profile anymore (as does 5.3.1)
and as a consequence the colours in the X3F review window are off, as can be seen very clearly in the comparison shot.
In short: it is not possible to make correct X3F adjustments in the review window anymore, becasue the colours displayed are wrong.
This is worse if you have a calibrated monitor; ie using the new (calibrated) colour profile as default and working in a colour space other than sRGB.
Again: if you just use SPP 5.3.2 to generate a Tiff and then process the Tiff in PS, for instance, then you will not have any problems. "
Dann mal die vorherige Version wieder installieren und warten.
Gruß,
Rico
