Video Panasonic Lumix TZ41 + TZ40 + TZ36 + TZ35 ( ZS30 + ZS25 )
the6thday
Für die dies interressiert hier mal die Mediainfo Daten von TZ41 videos:
AVCHD
Code:
General
Complete name                            : H:\PRIVATE\AVCHD\BDMV\STREAM\00000.MTS
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 45.4 MiB
Duration                                 : 13s 579ms
Overall bit rate mode                    : Variable
Overall bit rate                         : 28.1 Mbps
Maximum Overall bit rate                 : 28.0 Mbps
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.2
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Codec ID                                 : 27
Duration                                 : 13s 460ms
Bit rate mode                            : Variable
Bit rate                                 : 26.5 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 50.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.256
Stream size                              : 42.9 MiB (94%)
Audio
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : 129
Duration                                 : 13s 472ms
Bit rate mode                            : Constant
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 316 KiB (1%)
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 12s 956ms
MP4
Code:
General
Complete name                            : H:\DCIM\101_PANA\P1010077.MP4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 26.5 MiB
Duration                                 : 10s 560ms
Overall bit rate                         : 21.1 Mbps
Encoded date                             : UTC 2013-03-28 17:28:42
Tagged date                              : UTC 2013-03-28 17:28:42
PANA                                     : DMC-TZ41
Video
Format                                   : AVC
Format profile                           : Baseline@L4.0
Format settings, CABAC                   : No
Format settings, GOP                     : M=1, N=6
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 20.4 Mbps
Maximum bit rate                         : 24.0 Mbps
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.393
Stream size                              : 25.7 MiB (97%)
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Bit rate                                 : 128 Kbps
Stream size                              : 161 KiB (1%)
Erste Beobachtungen bei den TZ41 Videos:
Der Qualitätsunterschied zwischen AVCHD 1080p50 und MP4 1080p25 ist marginal, die Videos im MP4 Modus sind heller in dunklen Umgebungen, da ja nur 25 anstatt 50 Bilder pro Sekunde vom Sensor geliefert werden müssen ist dort wohl die Belichtungszeit höher, was auch zu weniger Hintergrundrauschen führt, wenn es hell genug ist sieht man den Unterschied allerdings nicht mehr, dort dürften dann die 50 Bilder/s im AVCHD Modus eher relevant für bessere Videos sein.
Beispiel AVCHD 1080p50:
http://the6thday.de/tz41bsp1.MTS
Beispiel MP4 1080p25:
http://the6thday.de/tz41bsp2.MP4
Aufgefallen ist mir auch dass der Autofokus im MP4 Modus wesentlich langsamer Arbeitet und bei voller Ausnutzung des Zoombereiches erstmal 1-3 Sekunden braucht um wieder ein scharfes bild zu produzieren, währen das im AVCHD Modus sofort passiert:
Fokus AVCHD:
http://the6thday.de/tz41zoom1.MTS
Fokus MP4:
http://the6thday.de/tz41zoom2.MP4
glücklich wirst du mit dem ding wohl nicht. wirds nochmal ne 36?
Die TZ 36 hat leider nur Mono ton...
Ansonsten war das oben geschriebene lediglich eine feststellung und nicht negativ gemeint.
Ich werde die TZ41 wie gesagt hauptsächlich dafür verwenden Videos auf Konzerten aufzunehmen, dort ist meiner Meinung nach schon die TZ31 der Konkurrenz(z.b. HX20v) überlegen in sachen Bildschärfe und Detailgrad.
Der Autofokus im AVCHD modus ist der TZ10 weiter überlegen, der Bildstabilisator macht bis jetzt auch einen ganz brauchbaren Eindruck und mit lauter Musik kommt sie auch klar(zumindest mit den pegeln die ich meinen nachbarn zumuten wollte :D) aber das war bei den panas ja schon seit der TZ7 kein Problem mehr.
Ansonsten hätten wir da noch 1080p50 anstatt 720p25 bei der TZ10, von daher ist die TZ41 schon ein großer Sprung nach vorne für das was ich damit machen werde.
Ich werde die TZ41 wie gesagt hauptsächlich dafür verwenden Videos auf Konzerten aufzunehmen....
hast du schon Videos mit der 41 aufgenommen? also nicht nur testvideos, sondern Konzert oder ä.?
ist die 41 gegenüber der 31 im videobereich besser?
ob die 41 wesentlich besser als die 31 ist kann ich dir nicht beantworten, mit konzertvideos von der 41 kann ich erst am am 17.04 dienen.
;) ok Der Tag war schon. Ich denke du meinst den 17.4
Da ich am 20.4 auf ein Konzert gehe, ist es da zu spät. Ich muss mich da jetzt für eine entscheiden.
Was mich noch interessiert, ist die Tonaufzeichnung direkt von der Kamera. Die 41 hat ja Stereotonaufnahme.
Bei vielen Konzertvideos von anderen Kameras, wie auch von Canon sx 260 (xxx) die ich mit in meine Überlegung einbezog, hört man oft das übersteuern/überschreien. Also grausiger Ton vom Konzert oder kommt es da auf den Standpunkt im Konzert an?
Bei den TZ habe ich bisher was ich gesehen und gehört habe da eine bessere bis sehr gute Tonqualität gehört, oder wurde da mit externer quelle gearbeitet?
Leider kommt man ja privat nicht mit dslr in solche Konzerte, dann bräuchte ich keine neue kompakte :D
Die Canon habe ich durch das bisher gesehene, gehörte (Ton, BQ im Video) und auch wegen der Aufnahme Formate ausgeschlossen. MP4 ist für mich einfacher zu Händeln, da ich mich im Bereich Video nicht wirklich auskenne und es auch bei Konzertmitschnitten und privaten Bereich bleiben wird.
geniesse lieber das Konzert und mach Dir das Liveerlebnis nicht kaputt für einen lausigen Mitschnitt, schaut doch späer niemand mehr an.
Sooo,
wie angekündigt, Konzertvideos von der TZ41
http://www.youtube.com/playlist?list=PLULQrYBLlX0Y3jJ5UTl5g2eNuv9uJNNXP
Videos im Orignalformat Unbearbeitet direkt von der Kamera gibts hier:
http://the6thday.de/videos/
Dafür dass Bühne und Sängerin die meiste Zeit recht spartanisch ausgeleuchtet waren sind die Ergebnisse meiner meinung nach sehr gut geworden.
Der im Vergleich zur TZ10 wesentlich schneller arbeitende Zoom ist während dem Filmen auch sehr hilfreich.
Der Ton ist der TZ10 eindeutig überlegen und selbst bei der Extremen Lautstärke in der ersten Reihe hat die TZ41 keinerlei Probleme. :top:
danke @the6thday
habe mir mittlerweile die TZ31 geholt. Bin mit der optischen Leistung bei 20fachen zoom und der tonaufnahme wirklich zufrieden. der Fokus braucht nur manchmal etwas bis er sich scharf stellt und die Kamera mit ausgestreckten armen über mehrere Minuten hinter eine wackelnde meute still zu halten, ist schon sehr schwierig :p.
aber für meine Zwecke reicht mir die tz31 völlig aus :top: bin zufrieden.
danke für dein feedback
Recht herzlichen Dank für die Videos, genau danach habe ich gesucht - ich denke ich werde sie mir mal bestellen und auf Festivals testen im elektronischen Bereich um zu sehen wie sie mit extremen Bassspitzen umgehen kann.
TZ 41 Videoqualität
Das Display der TZ 41 zeigt eine sehr gute Ausleuchtung des Raumes. Die Fotos werden in gleicher Qualität geliefert wie es das Display zeigt. Drücke ich die Aufnahmetaste für Video, verdunkelt sich das Display und die Videoaufnahmen sind entsprechend auch dunkel. Bei Vergleichsaufnahmen mit der TZ 36 tritt dieser "Mangel" nicht auf. Die Kamera ist 2 Monate alt. Die Einstellung ist der Auslieferungszustand. Wo liegt das Problem?
Huhu,
und die nächste Ladung Konzertvideos von der TZ41:
P!nk The Truth About Love Tour aus Mannheim:
Hier sieht man sehr schön welche Qualität die TZ41 erreichen kann bei Nahaufnahmen mit Maximalzoom, schon beeinduckend für so eine kleine Kamera :top:
http://www.youtube.com/playlist?list=PLULQrYBLlX0Z-Wa8TVjP-uJXAxUM0oae2
Und Mylene Farmer Timeless 2013 Tour aus Straßburg:
http://www.youtube.com/playlist?list=PLULQrYBLlX0ZP8M0ADN6g266PZAUHzfO2
Die Videos im Orignalformat Unbearbeitet direkt von der Kamera gibts hier:
