Flexx
Wie im Titel beschrieben verkaufe ich diesen kaum gebrauchten Filter.
Preis incl. Versand:
30 Euro
Daten vom Hersteller:
Warm Circular Polarizer Glass Filter - Light rays which are reflected become polarized. Polarizing filters are used to select which light rays enter your camera lens. They can remove unwanted reflections from non-metallic surfaces such as water or glass and also saturate colors providing better contrast. The effect can be seen through the viewfinder and changed by rotating the filter.
NOTE: Circular polarizers are specifically designed for use with auto-focus SLR cameras (They will also work on manual systems without problems). Linear polarizers are used with most video and manual focus photo cameras. They are not recommended for auto-focus SLR cameras
• This unique filter is the result of a collaboration between Hoya and respected wildlife photographer, B. Moose Peterson
• It combines the advantages of a polarizer with the warming effect of an 81A filter
• The filter factor varies according to how the filter is rotated and its orientation to the sun
Specifications
Type Warm Circular Polarizer - Moose Peterson
Size 72 mm
Grade Not applicable
Filter Factor Between 2.3 and 2.8 (approx. +1.3 stops)
Multi-Coated No
Rotating Yes
Effect Combines a circular polarizing filter with an 81A
Application Nature, outdoor photography
Color Temperature 81A decreases color temperature from 3400 - 3200 degrees Kelvin
Construction Glass
Front Filter Thread Size 72 mm
Front Lens Cap Size 72 mm
30 Euro
Specifications
Size 72 mm
Multi-Coated No
Rotating Yes
Construction Glass
