Reserviert/Verkauft/Erledigt DSLR IGUS Kamera Slider mit Timelapse Funktion
webster7567
ich verkaufe einen Motorslider mit 2 (!) Motoren für eine DSLR oder ähnliche Kameras. Ich hab diesen Slider für ein Projekt benötigt, jetzt liegt er nur herum.
Beschreibung von dem damaligen Verkäufer:
To use as a belt driven motorized slider and time-lapse slider and as a handslider Interchangeable without tools within 1 minute Rail and carriage 100 cm rail by Igus Carriage 75 x 75 mm Perfectly balanced friction Quiet Operation No metal-on-metal contact if scratched No oil needed For quiet and smooth recording Material hard anodized grade aluminium Plastic bushes enables smooth movements of the carriage Rail with 1/4” and 3/8” threads to mount 1 or 2 tripods Slider with 1/4” and 3/8” thread for camera or ballhead mounting Feet adjustable in height with surface protector Max. weight in horizontal position 5 kgs. Max. weight in vertical position 3 kgs. Motor Unit Low noise slidermotor with gearbox Speed appr from 50 cm till 600 cm per minute Plug for remote cable Quick change carriage Adjustable belt tension Time Lapse unit Low noise timelapsemotor with gearbox Speed appr from 1,5 cm till 10 cm per minute Plug for remote cable Quick change carriage Adjustable belt tension Remote Control Unit On/Off power switch with led indicator Left/0/Right direction switch Stepless speed regulator Plug for connecting charger Plug for connecting remote cable Automatic fuse 2Ah 12V 2Ah rechargeable battery (built-in) Remote cable 150 cm 12V Automatic battery charger / power supply Automatic battery detection Led indication for loading and loaded Can also be used as a 220V power supply
Das Angebot beinhaltet:
1 x Igus rail 100 cm length 50 mm width type WS-10-40
1 x carriage 75 x 75 mm
1 x 1/4” inch screw (for mounting camera/ballhead on carriage)
1 x 1/4” to 3/8” thread adapter (for mounting ballhead on carriage)
2 x adjustable feet with surface protectors
1 x 12V slidermotor unit with pulley
1 x 12V time lapse motor unit with pulley
1 x tooth belt for 100 cm rail
1 x endpulley
1 x remote control with build in battery 12V 2aH
1 x remote cable 150 cm
1 x 12V automatic charger/power supply
Als Bonus gebe ich den Kugelkopf noch mit dazu!!!!
Besichtigung immer möglich!
Hier der Link mit Fotos: https://www.willhaben.at/iad/kaufen...kl-timelaps-funktion-und-kugelkopf-132020422/
Abholung wird bevorzugt, Versand aber möglich! Zahlung per Nachnahme auch.
Preis: EUR 300,- und beim Versand komm ich entgegen...
