CF EXPRESS
Type B
SeriesVolume
SONYCEB-G seriesCEB-G128(128GB)*
CEB-G256(256GB)*
CEB-G512(512GB)*
LEXARProfessional CFexpress™ Type B CardLCFX10-64CRB (64GB)
LCFX10-64CRBNA (64GB)*1
LCFX10-128CRB (128GB)
LCFX10-128CRBNA (128GB)*1
LCFX10-256CRB (256GB)
LCFX10-256CRBNA (256GB) *1
LCFX10-512CRB (512GB)
LCFX10-512CRBNA (512GB)*1*1 Model number for North AmericaProGrade DigitalCobalt 1700RPGCFX325GCPNA (325GB)
PGCFX650GCPNA (650GB) SanDisk CFexpressExtreme Pro SeriesSDCFE-064G-ANCNN (64GB)
SDCFE-128G-ANCNN (128GB)
SDCFE-256G-ANCNN (256GB)
SDCFE-512G-ANCNN (512GB)
Canada: XXXG-CN4NN
Global: XXXG-GN4
(Eur/Asia-Pac/Aus/LatAm/MidEast/Africa)
Model numbers with NN have been tested
Mode numbers with IN are not supported
XQD
SeriesVolumeSONYG seriesQD-G32A / QD-G32E (32 GB)
QD-G64A / QD-G64E (64 GB)
QD-G128A / QD-G128E (128 GB)
QD-G256E (256 GB)
QD-G120F (120 GB)
QD-G240F (240 GB)
M seriesQD-M32 (32 GB) **
QD-M64 (64 GB) **
QD-M128 (128 GB) **NIKON MC-XQ64G (64 GB)
MC-XQ120G (120 GB)
* Nikon brand XQD cards are sold only in Japan
CFexpress or XQD cards with a maximum data transfer rate of at least 250 MB/s are recommended for high-speed frame capture
CFexpress or XQD cards with a maximum data transfer rate of at least 45 MB/s (300x) for video recording and playback
CFexpress or XQD cards with a maximum data transfer rate of at least 250 MB/s are recommended for recording and playback of videos with a high frame size or rate. Slower speeds may result in recording or playback being interrupted
To prevent damage to the camera or memory card, be sure to turn the camera off before inserting or removing the memory card.
Memory cards inserted in the camera may become hot. The number of shots possible may be reduced depending on the brand/model of the memory card
If camera temperature rises, recording may end before the maximum length or size is reached
XQD cards have slower data transfer rates than those of CFexpress cards. Therefore, if XQD cards are used when recording video with "ProRes 422 HQ 10-bit" selected for the video file type, recording may end in a short period of time. In addition, if XQD cards are used when recording H.265 or H.264 video at high temperatures, recording may end before the maximum length or size is reached even if the camera temperature does not rise.
* Recording at high temperatures may end before maximum length or size is reached, even if the camera temperature does not rise.
** Not suited for video recording due to the slower data transfer rates of the memory cards compared to other approved memory cards.
Die Preissuchmaschinen wirst du vermutlich selber finden?
