Bibble 4.4 ist raus............
  • Themenersteller Themenersteller Gast_291107
  • Erstellt am Erstellt am
Gast_291107
Guest
This is a free update for all users of Bibble 4.x. Merely download and install the new version. Your existing unlock code will continue to function just fine.
Some Highlights:
New Cameras:
Canon 5D, 1D Mark II N
Pentax *ist DL
Konica/Minolta A200, 5D
Fill Light (Shadow Recovery)
Since the introduction of our highlight recovery feature, we?ve received many requests for a similar tool that would help restore shadow detail. Using a single slider, it is now possible to brighten the darkest portions of your images, while leaveing the overall balance of the image the same. Like th HR tool, the fill light tool only modifies a portion of the image?s histogram making it easy to quickly get the results you desire without worrying about blowing out the rest of the image.
Sharper Output
Today?s newer cameras are featuring strong anti-aliasing filters which result in images with fewer artifacts. With this in mind, we?ve provided a new option to disable Bibble?s built in artifact reduction. This is now the default and will result in sharper images with less color moiré when compared to previous versions of Bibble. Older images might exhibit slight more noise and/or an occasional artifact. Should this occur, enable the artifact reduction routines from the sharpen/noise palette.
GPS Info
Bibble now display and exports GPS position info embedded in source file.
Tethering Updated.
In addition to adding tethering support for the newest Nikon and Canon Cameras, 4.4 once again support tethered shooting on the Macintosh with canon cameras.
Check out the home page at www.bibblelabs.com for more links and info.
Bibble 4.4 8/17/05
Added Support for Canon EOS 5D, EOS 1D Mark II-N
Added Support for Konica Minolta Maxxum 5D, Dimage a200
Added Support for Pentax *ist DL
Added tethered support for Nikon D70/S/D50
Added Tethered support for Canon 5D/1D2N/350D
Added option to disable demosaicing artifact reduction. Defaults to off, sharper images.
Added Fill Light (Shadow recovery)
Added Display/Export of GPS data from raw files that include it (location subset)
Added drag and drop onto the application icon or dock icon. [MAC]
Added total number of images selected to title bar
Added some protection against corrupt CRW files to prevent Bibble from locking up.
Fixed black border for images from the Canon Pro 1
Fixed Command-Click selecting in Browser window. [MAC]
Fixed a problem with status bar information when navigating with the keyboard
Fixed crash resulting from use of File:Close rather then the window close button.
Fixed Bibble plug-in manager to no longer attempt to load non-dlls under Windows
Fixed the clip rectangle for the Canon Pro1
Fixed Arbitrary rotation angle is now preserved in batch queues with "preserve rotation" set
Fixed Lock aspect should now work properly when dragging the crop rect
Fixed Crop grid lines will be erased when dragging stops if preference is set to "Dragging only"
Fixed problem with generating previews for folders with large numbers of images
Fixed incorrect WB with 20D Custom WB shots.
Fixed export of IPTC information for TIFF files.
Fixed problem with attempting to select all tagged files before the browser is done loading the file list.
Fixed problem with the Recent Browsers function under Windows, i.e. it should actually work now.
Fixed problem with EXIF export of rational values.
Fixed EXIF problem that could result in corrupt files on mac.
Fixed problem preventing display of Exif in converted files.
Fixed problem that could cause previews to be regenerated (Slower browsing)
Changed Minimum value for the white balance temperature slider is now 2000 instead of 2500
Changed Fit button in Crop/Rotate to account for straightening angle
Thanks for your support
-The Bibble team
Press release at: http://www.bibblelabs.com/pages/press/pr20051017.html
