markusberger
http://www.newsdesk.se/pressroom/so...hoeg-upploesning-och-hoeg-bildkvalitet-188410
Quelle: dpreview
a200 Key Features
Camera type-
Digital SLR with built-in flash and interchangeable lenses
Lens mount-
Compatible with Sony lenses and Konica Minolta/Minolta MAXXUM/
DYNAX lenses
Image sensor-
APS-C size CCD with anti-dust system
Sensor resolution- 10.2 effective megapixels
Image processor- Sony BIONZ engine
Image stabilisation-
Super SteadyShot with approx. 2.5 – 3.5 EV decrease in shutter speed (actual stabilisation depends on shooting conditions and lens)
Noise reduction- Long exp. & High ISO NR at ISO1600 / 3200
Creative Styles-
Preset modes: Standard, Vivid, Portrait, Landscape, Night View, Sunset, B/W, Adobe RGB. Adjustable parameters: Contrast, Saturation, Sharpness
D-Range Optimiser-
Operating modes: Off, Standard, Advanced
Scene Selection modes- Portrait, Landscape, Macro, Sports, Sunset, Night Portrait / Night View
Viewfinder-
Field of view: 95% / Magnification: 0.83x
AF system-
TTL phase detection, centre-cross 9-point
Sensitivity-
ISO100 - 3200 equivalent(Recommended Exposure Index)
Light metering- 40-segment honeycomb with multi-segment, spot and centre weighted modes
Flash modes-
Auto, Fill-in, Wireless, Rear, High Speed Synchro and Slow Synchro (Wireless and High Speed Synchro modes require optional accessory flash HVL-F56AM or HVL-F36AM)
Built-in flash system-
Auto popup (GN 12) with manual popup button
Shutter speed range- 1/4000 sec. - 30 sec., bulb (Flash sync speed 1/160 sec.)
Continuous shooting rate-
Up to approx. 3 fps
Max no. of frames- JPEG Fine/Std: unlimited (until memory card is full), RAW+JPEG: 3, RAW: 6
recordable (continuous)
Monitor screen-
Transparent TFT / 2.7-inch Clear Photo LCD (230k dots) with AR coating
Histogram display- Brightness, RGB
Function menu-
Camera Function Display with direct control of Flash Mode, AF Mode, WB, Metering Mode, AF Area, DRO
Battery type-
NP-FM500H with InfoLITHIUM % power remaining display on screen
Battery life- Approx. 750 shots (CIPA measurement)
Vertical control grip-
VG-B30AM (optional) accepts up to 2x NP-FM500H batteries
Recording media-
CompactFlash card: Type I, Type II (Microdrive)
Memory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO-HG Duo with optional adaptor.
Dimensions-
(WxHxD) Approx. 130.8 x 98.5 x 71.3 mm (excl. protrusions)
Weight Approx. 532 g (w/o batteries or memory card)
Quelle: dpreview
a200 Key Features
Camera type-
Lens mount-
DYNAX lenses
Image sensor-
Creative Styles-
D-Range Optimiser-
Viewfinder-
AF system-
Sensitivity-
Flash modes-
Up to approx. 3 fps
Monitor screen-
Function menu-
Battery type-
Recording media-
Dimensions-
