DSLR-Forum Anzeige
Zurück   DSLR-Forum > Handel > Biete > Biete - Zubehör
Hinweise
Anzeige
Antwort
Themen-Optionen Ansicht
Alt 13.02.2020, 20:53   #1
hwd
Benutzer
Standard Letus Helix Jr Gimbal
Werbung
Zu viel Werbung?
Hier kostenlos bei DSLR-Forum.de registrieren!
Ich verkaufe meinen Gimbal
Letus Helix Jr
  • Original Design: Designed from the ground up specifically for cinematography, not after thought like the rest of the gimbals on the market which put a handle onto the copter gimbal system.
  • Optically-centered: To minimize sensor movement avoid robotic look in footage found with other gimbals.
  • Eye-level Filming: Your hands is at the lens level, not a foot higher like other gimbals. This make shooting a lot fatigue.
  • Quick Balancing: It's a lot easier to balance each axis individually than making all 3 axis balance at the same time. Lens change is easier with simple adjustment of a single axis due to optical center design.
  • Flat-bottom Design: You can put the gimbal down between shots without needing a stand.
  • Intuitive Tilt Handle: The right handle of the gimbal acts as a joystick for tilting the camera up and down. This is the best loved feature.
  • Seamless Suitcase Mode Transition: Going from eye-level to low mode seamlessly by just letting go of the left handle.
  • Custom Firmware
  • Made In USA
SPECIFICATIONS:
  • 3-axis stabilization
  • WiFi and Bluetooth installed
  • Payload up to 8lbs = 3,6kg (up to 12lbs = 5,4kg if the the setup is less than 8" long)
  • Weight:
  • Aluminum: 5.25lb without battery / 5.75lb with battery
  • Dimension: 16" (40 cm) span handle to handle
  • 2,600mAh 14.8V Lithimum-ion battery and charger included (0.5lb)
  • Compatible with:
  • Mirrorless cameras
  • DSLR cameras
  • Mid-size cine cameras (setup must be compact)
technischer Zustand: sehr gut
optischer Zustand: sehr gut
Lieferumfang: Gimbal mit Akku und Ladegerät lt. Abbildung 3 (Kamera und Cage sind nicht dabei)
Ich hätte gerne EUR 800,- für den Gimbal.
Gerne Abholung in Amstetten (AT)
Privatverkauf: keine Garantie und keine Gewährleistung.
Angehängte Grafiken
Dateityp: jpg 20200213_181438_8664.jpg (481,0 KB, 5x aufgerufen)
Dateityp: jpg 20200213_182433_8668.jpg (382,6 KB, 4x aufgerufen)
Dateityp: jpg 20200213_182947_8670.jpg (427,3 KB, 1x aufgerufen)
Dateityp: jpg 20200213_183131_8671.jpg (366,3 KB, 0x aufgerufen)
Dateityp: jpg 20200213_183344_8672.jpg (377,6 KB, 1x aufgerufen)
__________________
Flickr
360cities
hwd ist offline   Mit Zitat antworten
Antwort
Themen-Optionen
Ansicht
Nutzungsbedingungen
BB-Code ist an.
Smileys sind an.
[IMG] Code ist aus.
HTML-Code ist aus.
Gehe zu
Alle Zeitangaben in WEZ +1. Es ist jetzt 21:36 Uhr.
Anzeige
Zu viel Werbung?
Kostenlos registrieren!
Anzeige
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
Copyright ©2003 - 2020, DSLR-Forum.de
Akzeptieren
