DSLR-Forum Anzeige
Zurück   DSLR-Forum > Technik und Gestaltung > Fototechnik > Technik
Hinweise
Anzeige
Antwort
Themen-Optionen Ansicht
Alt 24.01.2017, 20:19   #611
derkiki
Benutzer
Standard AW: Canon-EOS-Protokoll
Also, if anybody needs to know about starting the IS, just ask...
Hi John,
Could you please let me know how to start the IS?
Thanks
derkiki ist offline   Mit Zitat antworten
Alt 13.02.2017, 22:17   #612
raydem
Benutzer
Hello,
I trying to modify the sigma lens 28-200 mm aspherical IF. I have a 1000D canon. I want to use the ATTiny10, to reduce the power consumption. Does anyone have the last code or some code for this chip?
Thank you
raydem ist offline   Mit Zitat antworten
Alt 12.03.2017, 16:37   #613
i2c
Benutzer
Zitat:
Hi John,
Thanks
Hello,
Please check my post #600 on page 60 on this thread. Maybe next posts can be usefull.
Unfortunately I don't have the time to work on this project for now.
i2c ist offline   Mit Zitat antworten
Alt 25.05.2017, 10:36   #614
pulsartomi
Benutzer
Lächeln AW: Canon-EOS-Protokoll
Hallo, ich würde mich jemanden bitten, mir die HEX file zu schicken (pulsartomi@gmail.com). Der Download-Link funktioniert nicht.
Vielen Dank.
Geändert von Manni1 (23.05.2018 um 17:33 Uhr)
pulsartomi ist offline   Mit Zitat antworten
Werbung
Alt 23.05.2018, 01:02   #615
bdang
Benutzer
Hello everyone,
Sorry I don’t speak German.
I hope someone here can help me. I had read through the whole post and cannot find the answer I’m searching for. I would like to control the focus without using the Canon camera, but by using a microprocessor via the SPI serial bus. I can move the focus to INF using 0x05, then move to minimum focus using command 0x06, then command 0xC0 to read USM motor encoder position in int16, which is 0xE556. This means encoder count at INF = 0 and at minimum focus = 0xE556. This also means now if I give command 0x44 + 0x1AAA (0x1AAA = 0 - 0xE556) then focus should move to INF in 6828 (0x1AAA) steps. However I found the encoder is losing count when read with command 0xC0 after checking motor is stopped with 0x90 0xB9 status command. For example, from minimum focus and move with 0x44, 0x0300, the lens moved to 1 meter (read by 0xC2), and 0xC0 read 0xE856 (0XE556 + 0x0300 = 0xE856). However if I repeat this many times (0x44 0x0300 from minimum focus), lens at 1 meter but 0xC0 reading encoder does not give the same 0xE856, but instead 0xE846. Does this mean there is error in encoder count with 0xC0 command and what is the reason? My goal is to use command 0x44 + x to move the focus to location x ( 0 >= x >= 0xE556) and using 0xC0 for position feedback as below (cannot use C2 for position feedback because its value is not linear and no relationship to USM step in command 0x44):
While(1)
........enc = 0xC0(0x00); // read encoder count
........steps = x – enc;
........while(steps != 0) //
...............0x44 (steps);
...............wait motor stopped with 0x90 0xB9;
Thank you,
Brian
Geändert von bdang (23.05.2018 um 01:07 Uhr)
bdang ist offline   Mit Zitat antworten
Alt 23.05.2018, 19:23   #616
bdang
Benutzer
Btw, in the captured commands during the camera doing AF, I cannot see a single 0x44 focus move command being used. So what other focus move commands that the camera used?
Best Regards,
Brian
Alt 18.10.2018, 17:24   #617
vd86
Benutzer
ich besitze ebenfalls ein Sigma Super Wide II 24mm 2.8
Das Objektiv funktioniert problemlos an meiner 600D und 6D, inkl. Autofokus.
Aber eben nur mit Blende 2.8
Bei allen anderen Blenden kommt ein Fehler, ist ja bekannt.
Kurz und knapp:
Gibt es mittlerweile einen Workaround dafür?
Gerade an der 6D ist das Objektiv ein schönes WW und es wäre super, wenn man abblenden könnte.
Geändert von vd86 (18.10.2018 um 22:55 Uhr)
vd86 ist offline   Mit Zitat antworten
Antwort
Stichworte
canon ef , protokoll
Themen-Optionen
Ansicht
Nutzungsbedingungen
BB-Code ist an.
Smileys sind an.
[IMG] Code ist an.
HTML-Code ist aus.
Gehe zu
Alle Zeitangaben in WEZ +1. Es ist jetzt 03:29 Uhr.
Anzeige
Zu viel Werbung?
Kostenlos registrieren!
Anzeige
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright ©2003 - 2019, DSLR-Forum.de
Akzeptieren
