butcher1995
ich biete hier meine wenig genutze Fototasche der Qualitätsmarke F-stop.
Ein unbenutztes Raincover ist ebenfalls dabei. Ich hätte gern EUR 75 zzgl Versand für die Tasche.
Hier kommt die Original-Beschreibung von F-stop:
Weight: 1.29kgs (2.84lbs)
External (in): 13 depth x 16.5 width x 6.3 height
External (cm): 33 depth x 42 width x 16 height
Internal (in): 12.2 depth x 16.5 width x 5.5height
Internal (cm): 31 depth x 42 width x 14 height
Ideal for 17.3” as well as mounted pro body
Construction
- Hypalon® base and top panel provide impenetrable water protection in key areas
- Hypalon® ‘drip edge’ design naturally directs water off the top of the bag and prevents pooling
- Front pocket with accessory sleeve for organized packing
- Padded external sleeve
- Thermo-molded ergonomic back panel with logo detail
- Heavy duty shoulder strap with air-mesh design
Zippers & Fly
- Two (2) sizes to choose from, all built around popular professional photography laptop sizes
- Water-resistant Polyurethane-coated 330D Nylon body offers excellent splash protection
- Hypalon® in key areas allows bag to sit on wet surfaces and provide excellent rain protection in a storm
- Padded heavy duty shoulder strap helps reduce the weight of the gear load
- Four (4) GateKeeper mounting points for fastening the Ando tightly to a user’s body; allows fast movement without the bag swinging around and causing fatigue Lightweight and water resistant shell materials
- Lightweight and water resistant shell materials
- Large selection of dividers to help customize varied packing options
- Thermomolded back padding with subtle f-stop branding
- Two (2) large external side pockets
- Airline carry-on safe
- Lightweight
Es handelt sich um einen Privatverkauf. Umtausch, Rücknahme und Garantie sind ausgeschlossen.
Construction
Zippers & Fly
- Lightweight
