DSLR-Forum Anzeige
Zurück   DSLR-Forum > Community > Foto-Talk > Spekulationen
Hinweise
Anzeige
Antwort
Themen-Optionen Ansicht
Alt 14.05.2018, 08:41   #951
Inquisitor
Benutzer
Threadstarter
Standard AW: [Canon-EF/EF-S] KB - Festbrennweiten
https://photorumors.com/2018/05/13/n...f-1-8-ii-lens/
Eine neue Version des 50mm/1,8. Die alte Version scheint sich gut verkauft zu haben...
__________________
Ausrüstung steht im Profil
Inquisitor ist offline   Mit Zitat antworten
Alt 14.05.2018, 16:37   #952
michamelxp
Benutzer
Schon in deren eBay-Shop für 75 USD zu kaufen...
Zitat:
Specification:
Upgraded Yongnuo Lens YN50MM F1.8 II for Canon, compare with the first version YN50MM F1.8 for Canon, the two main added feature are:
1: 0.35m Closest Focusing Distance
2: Durable Metal Mount
3: Focus Distance Indicator is convenient for you to estimate the distance and the depth of field.
4: New Mechanical Structure, New Coating Technology
Features:
Supports USB-free Firmware Upgrade
Firmware of the lens can be upgraded through camera instead of using USB port, which not only meets the requirements of firmware upgrade and appearance design, but also avoids the incompatibility problems caused by different computer operating systems.(Note: this function needs to be supported by camera)
F1.8 Bright Aperture
Maximum aperture F1.8,bokeh effect is easily achieved ,which brings you more fun during photographing.
YN50mm F1.8 II has all the product advantages of the last generation. By improving the mechanical structure and coating technology, its focus accuracy, auto-focus speed and light transmittance are increased. Furthermore, it can control backlight ghost and glare.
Durable Metal Mount
YN50mm F1.8 II adopts chrome-plated and high-accuracy metal mount. It’s wearable, corrosion-resistant, and highly consistent with the body of the camera.
Compared with the first generation, the closet focusing distance of YN50mm F1.8 II is shortened to 0.35m.You can get closer to the object for photography and enlarge the object.
Focus Modes: Auto Focus (AF) and Manual Focus (MF)
YN50mm F1.8 II supports auto focus and manual focus. The focus mode can be selected according to practical requirement.
YN50mm F1.8 II has 7pcs of aperture blades, which helps to take picture of circular defocused spots or helps to stop down and take picture of 14-star effect.
Angle of View Diagonal 46 Degree
Vertical 27 Degree
Horizontal 40 Degree
Lens Structure 6 elements in 5 groups
Diaphragm Leaves 7pcs
Minimum Aperture F/22
Closet Focusing Distance 0.35m
Max. Amplificaton Factor 0.21X
MxP ( Filter diameter )/Number Available 58mm/1
Max. Diameter and Length approx 75x51mm
Suit for Canon DSLR Camera:
Canon 1300D 1200D 1100D 1000D 850D 800D 750D 700D 650D 600D 550D 500D 450D 400D 350D 7DII 7D 6D 5DIV 5DIII 5DII 5D 60D 50D 40D 30D 20D 10D 1D 1Ds
michamelxp ist offline   Mit Zitat antworten
Alt 14.05.2018, 21:10   #953
wilsberg
Benutzer
Da das YONGNUO YN50mm F1.8 II keine Spekulation mehr ist, geht das Thema (schon länger) hier weiter:
https://www.dslr-forum.de/showthread.php?t=1889844
wilsberg ist offline   Mit Zitat antworten
Alt 15.06.2018, 13:55   #954
Inquisitor
Benutzer
Threadstarter
https://photorumors.com/2018/06/15/s...t-coming-next/
Nach dem Samyang 14mm/2,8 kommt nun auch das Samyang 85mm/1,4 mit Autofokus. Das wird immer interessanter.
__________________
Werbung
Alt 15.06.2018, 15:37   #955
IchHabeEineNikon
Benutzer
Das könnte von der Größe schon was sein, aber zum Filmen ist ein IS/VC einfach eine feine Sache. Und dann ist es z.B. beim neuen Yongnuo so, das der AF nicht im Live-View funktioniert.
Am liebsten wäre mir immer noch das Canon 85mm 1.8 mit IS
IchHabeEineNikon ist offline   Mit Zitat antworten
Alt 15.06.2018, 16:17   #956
barba
Benutzer
Cool. Die größe gefällt mir. Wenn es optisch halbwegs Gut ist, ist es meines.
__________________
EOS 6D: EF 16-35/4L, EF 35/IS, EF 50L, EF 100/2, EF 135L,
EOS M6: 8/2,8, 11-22, 22/2, 15-45, 55-200,
http://www.flickr.com/photos/ustyle/
barba ist gerade online   Mit Zitat antworten
Alt 18.06.2018, 15:53   #957
Ultrazauberer
Benutzer
https://www.samyanglensglobal.com/en...ew.php?seq=380
__________________
Meine Bilder bei flickr oder unter flopix.de | FB
Ultrazauberer ist offline   Mit Zitat antworten
Alt 18.06.2018, 17:01   #958
barba
Benutzer
Etwa halbes Gewicht und halber Preis vom EF 85IS. Ich bin sehr gespannt wie der AF funktioniert und wie das Bokeh aussieht.
__________________
Alt 26.06.2018, 21:12   #959
ray10
Benutzer
Spekulationen gehen wieder los ob es ein 50L wird (womöglich mit IS)?
http://www.canonrumors.com/a-new-50m...-the-wild-cr2/
__________________
Glashalterung: 5D III + BG-E11 + GP-E2
Glascontainer: 11-24/4 L * 16-35/4 L IS * 24-105/4 L IS * 70-200/2.8 L IS II * 100-400/4.5-5.6
L IS II * 24/1.4 L II * 35/1.4 L II * 85/1.4 L IS * 100/2.8 L Macro IS * 1.4x III
ray10 ist offline   Mit Zitat antworten
Alt 27.06.2018, 07:57   #960
chickenhead
Moderator
Ja, und wieder nichts konkretes.
__________________
Gruß Thorsten
__________________________________________
Sony A9 | Canon EF 16-35/4 IS USM | Sigma 24-105/4 OS [CANON VERSION] | Sigma 35/1,4 HSM Art [SONY VERSION] | Sony 70-200/2,8 GM | Sigma 500/4 OS HSM Sports [CANON VERSION] | TC-1401 | MC-11 | 2x Godox 860II C | Godox 685 S | Godox XPro S
Meine Bilder
Beiträge als Moderator in Grün
Beiträge als User in schwarz
chickenhead ist offline   Mit Zitat antworten
Antwort
Themen-Optionen
Ansicht
Nutzungsbedingungen
BB-Code ist an.
Smileys sind an.
[IMG] Code ist an.
HTML-Code ist aus.
Gehe zu
Alle Zeitangaben in WEZ +1. Es ist jetzt 20:39 Uhr.
Anzeige
Zu viel Werbung?
Kostenlos registrieren!
Anzeige
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright ©2003 - 2018, DSLR-Forum.de
Akzeptieren
