Neue Funktionen in Canon DPP
Wo kann ich die Vollversion laden? Hab ja nur die CD der 1Ds II...
Ich bin ja mal gespannt, was es mit dem angekündigten DLO - Digial Lens Optimizer auf sich haben wird^^
Hier gibt es ein paar Infos - Zitat aus dem Interview unter der genannten URL:
http://www.arihazeghiphotography.com/AH_CW_interview/ schrieb:
AH: What new improvements are offered in the new Canon DPP software in combination with EOS 5D Mark III?
CW: We targeted three new features for the new version of DPP that will be released together with the EOS 5D Mark III:
· Support for the 5D Mark III’s HDR mode.
· Support for the Multiple Exposure mode of the 5D Mark III and EOS-1D X.
· A new feature called Digital Lens Optimizer processes RAW images to achieve ideal optical characteristics for all types of optical aberration or diffraction, effects of a low-pass filter in front of a CMOS sensor, etc. This function improves image quality particularly in the image periphery in addition to the image center. This function is made possible because the entire design-through-manufacture process, for camera, CMOS sensor, EF lens, and DPP, is carried out entirely at Canon. Images are processed optimally using lens information in the image files (focal length, subject distance, and aperture) and lens data specially for the Digital Lens Optimizer. (However, the size of a .CR2 file will be two to three times larger after applying the Digital Lens Optimizer.) Adjustments are made for such aspects as spherical aberration, chromatic aberration, astigmatism, curvature of field, sagittal halo, chromatic aberration of magnification, axial chromatic aberration, diffraction, and the effects of a low-pass filter in front of the CMOS sensor. DPP’s Digital Lens Optimizer will be usable with any of 29 compatible lenses initially. It works with .CR2 files from EOS models released since 2006 (EOS 30D and forward).
Heist das, dass die Korrekturen in das CR2 hineingerechnet werden und so mit einem anderen RAW-Konverter (ohne den Umweg als TIFF) weiterverarbeitet werden kann?
Macht DPP ein Backup vom Orginal-CR2 ?
Lars
Zitat aus dem Interview unter der genannten URL: It works with .CR2 files from EOS models released since 2006 (EOS 30D and forward)
oooh jaaaa... :top:
Hier mal die Objektive die von DPP’s Digital Lens Optimizer unterstützt werden.:top:
oooh jaaaa... :top:
Das ist echt mal ein Update, auf das ich extrem gespannt bin. Wenn man das ganze Marketing-geschwafel durch den Marketingfaktor dividiert, kommt nämlich immer noch ein interessantes Tool raus. Im Prinzip ja die technische Philosophie von Apple-Computern (Kann sich da noch wer erinnern?!), denn die Wege des Lichts kennt man hier im Optimalfall: Linse von Canon, Sensor von Canon, Software von Canon. Da lässt sich schon was herausholen, da bin ich schon mal vorsichtig optimistisch.
Die Möglichkeit ein "DPP-korrigiertes" raw-file mit Lightroom etc. weiterzubearbeiten wäre eine tolle Sache. Wenn es dann noch möglich wäre das korrigierte raw-file in ein Format wie dng zu konvertieren, wäre man u.U. in Zukunft deutlich unabhängiger von der Update-Politik von Adobe.
Das sehe ich auch so.
Hat das schon jemand im neuen DPP ausprobiert?
