The new fast ultra-wide zoom PRO
The new splash- and dustproof M.ZUIKO DIGITAL ED 7-14mm 1:2.8 PRO is the first wide-angle zoom lens in the M.ZUIKO PRO series. It inherits both the compact and lightweight M.ZUIKO PRO design as well as the optical fireworks. Like the new Fisheye PRO, the 7-14mm wide-angle zoom lens guarantees excellent optical performance quality from edge to edge. For example, with starscapes, it reproduces stars as circular points of light, even on the periphery of the frame. It’s also packed with practical PRO features, such as the manual focus clutch that lets you instantly switch from AF to MF by pulling the focus ring toward the camera body. There’s also an L-Fn button on the base of the lens that lets you make changes in an instant with your thumb – to one of your preferred pre-assignable settings.
Like the rest of the PRO family, this versatile and fast-focusing newcomer is fully weatherproof – thanks to 11 separate seals – and it’s out in the field that the wide-angle zoom comes into its own. It lets you get just 7.5cm from your subject (measured from the end of the lens), which is about 20% closer than equivalent rivals. Of course, the depth of field makes for excellent wide-angle backgrounds. The M.ZUIKO DIGITAL ED 7-14mm 1:2.8 PRO weighs just over half as much as equivalent 1:2.8 aperture rivals, so it’s perfect for spontaneous hand-held shooting, by day or at night. The combination with OM-D powerful in-body image stabilization ensures even wide angle shots come out sharp and clear.
