Sigma Objektive mit Sony E-Mount - Offiziell angekündigt
Status
ThreeD23
https://www.sigmaphoto.com/article/art-primes-for-sony-e-mount-announcement
"1. Autofocus tuned for each lens
Thanks to an autofocus drive control program tuned for each lens and high-speed data transmission,
the lenses will offer high-speed autofocus at the same performance level as that of a lens designed
exclusively for mirrorless cameras. In particular, in E-mount cameras offering Sony’s Fast Hybrid AF, AF-C mode will deliver exceptional subject following performance. Moreover, autofocus will remain extremely precise even in those E-mount cameras offering only contrast AF.
2. Compatible with in-camera image stabilization
The lenses will be compatible with in-camera image stabilization. The Sony E-mount camera senses
the focal length of the lens and automatically optimizes image stabilization performance.
3. Data loaded for compatibility with in-camera aberration correction
The lenses will be fully compatible with in-camera aberration correction, which includes corrections
for peripheral illumination, chromatic aberrations, and distortion. By matching corrections to the optical characteristics of the lens, this function takes image quality to an even higher level.
4. Native mount for a more rigid and stable feel
Making the mount native to the lens makes possible a more rigid and stable feel to the lens.
Featuring a special surface treatment to enhance strength, the brass bayonet mount offers a high-precision fit and exceptional durability. The mount connection area incorporates rubber sealing for dust- and splash-proof construction.
5. Available Mount Conversion Service
This service converts the mount of SIGMA lenses to that of a different camera body, allowing photographers to continue using their favorite lenses over the long term regardless of camera system."
Das ist doch mal was. (y)
AW: Sigma FE - Offiziell angekündigt
Das sind die DSLR-Objektive mit integriertem MC-11 und angepasster Elektronik, also ziemliche Klopper.
Solange das so ist, wir sich Sony nicht allzu sehr fürchten müssen, zumindest im Weitwinkel-Bereich. Aber es ist ein Anfang, und im Prinzip natürlich besser als eine adaptierte Linse.
Trotzdem habe ich mir mehr erhofft, z.B. das relativ kompakte 1,4/35, das in den Gerüchten kursierte.
Grüße,
Heinz
Das sind die DSLR-Objektive mit integriertem MC-11, also ziemliche Klopper.
Solange das so ist, wir sich Sony nicht so fürchten müssen, zumindest im Weitwinkel-Bereich.
Grüße,
Heinz
Nicht ganz. Mal genauer lesen. ;)
Ja, weil es aktuell ja soviele lichtstarke FB im WW Bereich mit AF von Sony gibt.
Ja, da sehe ich auch keinen Mangel.
Ich hatte eher auf 120-300 mit nativem Anschluss gehofft oder auf das 500/4 oder...
Aber wahrscheinlich ist Sigma mit der AF-Logik von den Zooms noch nicht so weit, sonst hätten sie bestimmt auch die Zooms direkt portiert.
Cool wäre ja das 14mm f/1.8, endlich ohne Adapter :cool: Bin ja mal gespannt.
Das 24-35mm/2.0 wäre mein Wunsch gewesen, war an der D800 schon mein Liebling, da sich in dem Bereich ca. 75% meiner Aufnahmen befinden. Aber an 35ern herrscht ja dann kein Mangel, alles dabei inkl. kleine manuelle.
Mich würden ja mal Gewicht und Maße interessieren, insbesondere beim 24/1.4 und 50/1.4. :D
Ja, dem schliesse ich mich an. Ich hatte es eine Weile adaptiert an der a7ii und es war wirklich ein klasse Werkzeug!
der wird natürlich dazu kommen, ich dachte die erwartungen gingen in die richtung dass es kleiner wird als beim Spiegel, unter vernachlässigung der Physik :)
Naja, ein Laowa 15/2 versus einem Sigma 14/1.8: Für 1mm weniger Brennweite und ⅓ Blende ein knappes Kg mehr - da kann man ja auch mal spekulieren, dass Sigma nicht einfach nur Elektronik-Adaptionen der vorhandenen Optiken macht.
natürlich kann man spekulieren, man kann auch AF und MF Objektive durcheinander werfen. Macht nur alles keinen Sinn wenn Sigma sagt sie bieten die ART Serie nun neben Canikon auch mit FE mount an. da bleibt ziemlich wenig Raum für Spekulation.
Samyang hat es doch in der Vergangenheit schon vorgemacht. Man nehme die CaNikon Variante, klatsche unten einen Adapter dran der das ganze dann 3-4 cm länger macht. Ja, Samyang hat keinen AF, aber sie waren ja auch mind. zwei Jahre früher dran.
ich finde es schon schade, dass hier Potential verschenkt wird. Interessant wäre auch ein Vergleich zwischen Sigma FE Variante und Sigma C + MC-11:rolleyes:
Status
